Best noctua just to bring temps and noise down for fx8350
Hi everyone. I am getting some new bits. I got a corsair 600T case in white Its super sexy. so I wanted to put a noctua fan/ h sink on it, to bring the noise down, and to cool it better. I wont be over clocking or going crazy. I live in a warm climate. so what is a mild update over the standard setup. that isnt huge. or too noisy??
fx8350 amd 8 core
:hello:
Thanks Toms :)
1 answer Last reply
More about best noctua bring temps noise fx8350
    fx8350 amd 8 core
    :hello:
    Thanks Toms :)
    you want noctua this
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16835608018
    but it's expensive and you can get as good for 1/4 the price , especially if you're not going to OC . coolmax 212 a bit noisy , deepcool 400 very quiet , as quiet as noctua , or the deepcool 300 that I use and is silent , keeps my OC @3.9 GHZ under 53c , at stock clocks under 42c , these temps are all cores @100% use .
    I use noctua np12/14 for all my case fans , they are quiet , but my deepcool fans are just as silent , ina few years Ill know if they last as long as noctua , have 3 4 year old noctua fans going 24/7
    note , the noctua and 212 you need to add backing plate to mount , not so with deepcool units
    here are my results at stock clocks after 4 hours @100% cpu use , temp in room 21-22c
Heatsinks Overclocking
