Since my last post have bought all the items listed below for my new build. Its been a while since I have done one of these. Some of the things are straight forward. He is my ststem. Thsn Ill throw a few questions.
MOBO- Gigabyte GA-P55A-UD3p
PS- OCZ550FTY 550W
CPU- i5 750
RAM- 4GB Kingston 1333
CASE- Antec 300
OPTIC DRIVE-Sony Optiarc24x SATA
OS-Win 7 Pro 64 bit
VIDEO Card- Gigabyte 4670
HDD-Used spare 80GB Western Digital IDE
Now like I said , some of the hook ups are a no brainer.I am in the building stage at this time.
Question1- The MOBO has a the standard ATX 2x12 connector for power. That is staright forward, no brainer, must be hooked up. There is also CPU power connector that is ATX 2x4 , is it to also required when using the i5 750 cpu? The manual says to use this connector when using extreme core cpu's
Question 2- The are several fan headers on this MOBO, the case came with 4 fans installed, 2front (blow in), 1 rear (blows out), 1 side.
The connectors on the MOBO headers are different than the ones used on the fans. The fans appear to be using a standard IDE HDD power connectors with male/female confirguration for what appears to allow for daisy chaining. Since I am not a over clocker or gamer, then all 4 fans at this time are no use to me.
Is it ok to use a spare IDE power connector to run the fans? 1 front, 1 rear
PS- OCZ550FTY 550W
CPU- i5 750
CASE- Antec 300
OS-Win 7 Pro 64 bit
