Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > internal battery replacement for emachines laptop?
Forum Laptops & Notebooks : General Laptops & Notebooks - internal battery replacement for emachines laptop?
Archived from groups: comp.sys.laptops (More info?)
My new emachines M6811 laptop only lasts for 1.5 to 3 hours (depending on
USB, CD-ROM, and display usage--3 hrs. only if closed, no usb, and quietly
used via remote desktop). I haven't found emachines listed as a brand of
supported battery by third party battery vendors anywhere.
Is there any hope other than an external battery unit?
Jon
Sponsored Links
external batt, yes, try ebatts.com
"Jon Davis" <jon@REMOVE.ME.jondavis.net> wrote in message
news:10i3pohb3maenb2@corp.supernews.com...
> Jon
Reply to Anonymous
I am not sure but I think you can find this battery at
www.batterysavings.com at
http://www.batterysavings.com/site [...] 5/1/a.aspx
It is not listed under that model but i believe this is the right
battery. Check the specs and try searching by OEM number on the
Emachines battery. Of course as suggested below you can also by an
external battery for it:
http://www.batterysavings.com/site [...] 0/1/a.aspx
or
Good Luck!
Oleg
"sava777" <sava777@comcast.net> wrote in message news:<KWqUc.174802$eM2.123139@attbi_s51>...
> > Jon
Reply to Anonymous
There are 493 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
