Power Supply problems
Last response: in Components
Hi guys
I recently upgraded components in my computer and got a GIGABYTE ODIN GT 800 Watt power supply
after installing it then booting then installing the program it comes with, when i load the program it comes up with HARDWARE CONNECT FAILURE
I took it into a computer shop because i couldn't be bothered fixing it but they said it was OK and that it runs fine
they said that it could be a OS problem but i ran the program on a XP and Vista(both 32 bit) computer and that's not it.
I was told that it could be Norton 360 software conflict
Any help would be appreciated
Thanks!
More about : power supply problems
bigred92 said:
Its a X48
I had no problems with it on an X48 , but it ran XP Pro and Norton Corporate Edition. Put 7 on the sytem , but had moved the power supply so have no idea if it would have worked or not.
My P55 used 7 Ult. 64b and no AV.
Currently have it hooked to an X58 with 7 Ult., again no AV , no problems.
Ask the community
