Will Deepcool Ice Blade Pro fit in my PC?
I was recently looking for the best looking "budget" HSF, and I found the Deep Cool Ice Blade Pro (which perfectly match my CPU's blue lit theme) now I will be ordering it but I was just wondering if it would fit in my PC? considering i am using an mATX motherboard.. Does anybody have any experiences regarding this?
Btw, here are my PC specs:
Cooler Master K380 PC Chasis - http://www.coolermaster.com/product.php?product_id=6861
ASUS P8H61-M LE (mATX mobo) - http://www.asus.com/Motherboards/Intel_Socket_1155/P8H61M_LE/
Intel Core i3-2100
FSP Epsilon 600w 80+
2x2gb G.Skil Ripjaws X
Inno3d GTS 250 (will be upgraded to either a GTX 650 Ti or HD 7850) - i was also wondering if the Deep Cool Iceblade Pro will fit after i get a new video card? Considering that the 650 ti and 7850 are relatively larger compared to my current video card)
Thanks :D
3 answers Last reply
More about will deepcool blade
  1. Any opinions please :(
    Intel Core i3-2100
    Thanks :D
    your case is 209mmwide and the cooler is 161mm tall , do yo have 168 mm between side of case and the cpu ? If yes it should fit link they have mounting instructions and dimensions , great cooler by the way . But don't use supplied paste , get TIM Tronics 4200 or Artic mx-2 or -4
    http://deepcool-us.com/Product/ICE_BLAD_PRO_V2/
  3. Imnot sure if i have 168mm between the side od the case and my cpu.. Anyway thanks for the advice :)
Heatsinks DeepCool Overclocking
