Help With Bare Drive
So I recently purchased the following items.
HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148506
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131760
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139025
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811108376
What I need to know is what do I need to get the HDD connected because it is a bare drive it will not come with any cables.
3 answers Last reply
More about help bare drive
  1. Nothing. The motherboard will come with the needed SATA cables needed to connect the HDD to the motherboard.
  2. Just to be curious , why did you buy such an expensive motherboard?
    I'm not completely sure what cables come with the motherboard but since you are getting a sata3 hdd you want to make sure that you are useing the sata3 cables that come with the motherboard.
  3. I wanted a motherboard that could handle 3xfire with overclocking it seemed like the most stable choice also it is cheaper than the new 2011 platform that I was going to get so I saved money in the end while still getting a beast board.
Hard Drives Motherboards Storage Product
