I'm building a new system from scratch and I'm stuck deciding between the 785G chipset with integrated graphics vs. buying a lower-end discrete card like a Radeon HD 4670 or such.
I'm planning to use the system primarily for (in order) virtualization (linux in a vm to do some web development), medium-duty image-editing, and dvd-ripping. Short-term, I do not intend to play games. I might down the road, so I'd like a setup that will allow me to upgrade later.
I'm planning to build the system around an AMD Phenom II X4 965 (or an X2 555 if I can find one)
So should I go with the 785G IGP or a low-end discrete card?
