Hi everybody.
My old pc is suffering and going to die soon I think. So I wanted to do an "upgrade" with a very low budget. Since I'm not citizen of US or Europe I, I don't use dollars and euro hence I can't name my budget in dollars. Ill just write a build that fits my budget and you will comment and suggest better things (if there are any).
So here it is:
CPU: Intel Pentium Dual Core S1156 2.8Ghz G9650 BOX
Motherboard: Gigabyte GA-H55M-S2H
RAM: 1x Kingston 2048MB DDR3 1333MHZ
Case: Raidmax Apex w/o PSU
PSU: Seasonic S12II 430W Bronze
CPU Cooling: Arctic Cooling Alpine 11 PRO
I wont change PSU cause its new (I bough it few days ago in hope that it will help my old PC). About hard-disks, I'm going to use the two I have now (ExcelStore 80GB and Hitachi 160GB both IDE), and LG DVD Rwirter with SATA.
Hardly I can update to Core I3, not sure if its needed tough.
I could build a cheaper system based on Dual Core E6500 (lga775 socket) but then there will be no way to upgrade in future.
Note: I'm not an overclocker and most likely wont OC the CPU.
What do you think? Have any suggestions?
Thanks!
So here it is:
Thanks!
