hey guys You may have seen some designs like this but im pretty happy with my setup. I recently built my new rig and bought this san ace mc liquid cooler made for the intel lga 775 socket. well i love hacking everything and decided to mount this to my new amd fx build. I could not be happier for the 25 dollars shipped i spent on this liquid cooler which even has a copper block. The radiator is actually a very good one, a little more over sized than the normal ones you could fit in the case with a 140mm fan i believe, i know its a little over 120mm. I had a nice bracket lying around from an old amd athlon/sempron that actually would flex a little and applied it to my processor. The temps at idle in a 80 deg f room are 10-15c all day long and on my cpu testing program under full load never goes above 35c. now as i had my peltier(tec1-12710 156w ) lying around i decided to try using it with my wAtercooler and a hacked copper based xbox360 heatsink. i luckily found a perfect clamp for it using the stock clamp that came with my fx processor. Ofcourse i tested it on my old athlon x2 5200 oc to 3.13 ghz. at idle it was usually around 40c. now as you can see in the pictures a huge difference. not sure why the 1st core always reads weird tho. Also max load is never above 5c, and i laid some foam around the processor to hopefully help if it ever started sweating. The fan i lazily laid near the heatsink since i already clamped it and didnt want unclamp it to screw it onto the heatsink.
i originally planned for the peltier to be on top of the cooler as you can see before i modified the heatsink for the bracket, it is now sitting directly on the processor which i really dont like since when the peltier is shut off it runs about just as hot as it did with the heatsink i had on there due to the fact they dont transfer heat that well when off.
sorry for rambling on but also the heatsink with just the peltier running was showing 37c, now monitoring the heatsink it shows 25-27c usually. these temps are all with this chinese grease like compound which i have tons of lying around
