Hey everyone. I dont post often unless I come seeking advice.
I do believe last might after about three years my motherboad seems to have kicked the bucket. On rebooting last night it seems to be stuck on the Gigabyte welcome screen and will only allow me to use the keyboard command to get into the post screen. It finishes the memory check and then nothing...once it said searching for IDE drives and just hung there.
I had a gigabyte GA-p35-ds3l LGA 775 and Im looking for something similar that will work with my components (pasted from my original NewEgg order).
I havent kept up on my motherboard news and products as this machine has been great for the better part of two years.
CPU = Intel Core 2 duo E8400 Wolfdale
GPU = MSI NX8800GTS 512M OC GeForce 8800GTS (G92) 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card (suits my purposes for now)
Ram = G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
The system currently was running Vista Home 64, but I will be picking up a new HD and installing WIndows 7 fresh and clean, and using the exisiting HD as justa slave drive.
Im not looking to break the bank and would like to salvage most of my parts if I can. I wasnt looking to build a whole new rig at the moment, bu i do need help in finding a new motherboard to work with what I have
Thank you in advance
Craig
Craig
