So I got myself a new computer built. Took about a month to actually put together once I got the parts and after barely even a week of use I'm getting BSOD problems. When it worked which was just for 3 days it was satisfying. One of the major things I didn't like however which I had decided wasn't worth to fret over and to just deal with it was that upon startup it would take 2 maybe 3 mins to load up all of Windows. This had me a bit drawn back as my older Compaq already built store bought computer loaded within seconds of hitting the power button. The only reason its still not in use is because I needed a gaming system and it just wasn't cutting it. Parts did not meet the requirements to run smoothly and they were simply all just too old to swap out. It was just cheaper at that point to build a completely new system.
Anyway slow startup aside my major problem right now is that on my new computer I keep getting the blue screen. It also likes to show it briefly, start up Windows and blue screen again. When I have been able to get a good look at the messages I noticed every time its something different. One time I saw it say memory_management and another time was system_service_exception. There have been others I was not able to read what they said since it would quickly switch off to try and start Windows again. Sometimes I would also just see a series of numbers only with STOP along the lines. The blue screening would also happen not as regularly at first. It would make it to Windows and allow me enough time to try and find the error messages which would tell me nothing other than the system had shut down unexpectedly then maybe 2 mins in blue screen again. Now it just immediately and always blue screens when turned on.
I checked the memory and can't find any reason why that'd be the problem as they haven't failed any tests done to them. The system reads that all 4gigs are there and report no errors. Even switched the sticks around. (And yes they're in their proper colored slots) yet while testing in safe mode its telling me there IS a hardware problem its just not telling me what.
I'm beginning to think even after cleaning the drivers and reinstalling when I get the chance to that the motherboard may be wonky and if it is I'd like a recommendation on a new different board. Preferably thanks to this experience I would like it not to be a Gigabyte board. Not saying its a bad brand but I have a bad taste in my mouth now. Doesn't help that my friends board is a Gigabyte too and also starts up incredibly slow. (its an older model from mine)
However if its not the motherboard I am still opening to suggestions on what the problem could be, if it still leads to that this motherboard is sensitive and known to not always being stable then I would still like to know of another that's not going to give me a headache.
GIGABYTE GA-P55A-UD4P (LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard w/ USB 3.0 & SATA 6 Gb/s)
Intel Core i5-760 Lynnfield 2.8GHz 8MB L3 Cache LGA 1156 95W Quad-Core
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V
Windows 7 64 Home
Windows 7 64 Home
