I am trying to get it to work but so far it hasnt, my HDTV is utilizing the HDMI, while my regular monitor is a 19inch samsung DVI, how come the HDTV screen is blank? I even turned on the multi moniter support in catalyst and my screen still states that little blue moniter 1 on the task manager?!
Is it the settings I need to tweak?
I am using the 5850, my drivers are updated so everything should work. I have used the HDTV but only with one screen and not dual.... what do you think is the problem?
