Help connecting 2x 3pin fans to 4pin mobo header
  • Heatsinks
  • Connection
  • Shark
  • Overclocking
  • Product
November 30, 2012 2:32:53 AM
I'm using an ASRock Z77 Extreme4 motherboard that has a 4pin fan header called CHA_FAN1. I'm trying to connect two Aerocool Shark 120mm LED fans to this header.
I bought this: http://www.newegg.com/Product/Product.aspx?Item=N82E168... to connect the fans to the one 4pin header on the mobo.
The Shark fans are only 3pin fans but come with an 4pin molex-3pin adapter. Can I connect the Gelid Solutions splitter to mobo, then connect the 4pin female end to the following?
Then connect that to the following molex-3pin adapter?
Then connect the adapter to the Shark fan? Will this power the fans and still allow for mobo controlled PWM functionality of the two Shark fans or am I going about this all wrong? I have a gut feeling that this is very jerry-rigged and ultimately wrong.
More about : connecting 3pin fans 4pin mobo header
a b K Overclocking
November 30, 2012 11:58:08 AM
you could do that only problem is if its when connecting a 3 pin to a 4 fan pin will cause the fans to run at full speed. also you could be drawing to much power through that one header with two fans.
m
l
a b K Overclocking
December 3, 2012 10:46:46 AM
you could wreck the header drawing to many watts through it or even kill the fans. you could get a cheap fan controller like this http://www.ebay.com/itm/DC-Fan-Speed-Controller-4pin-mo...
or even get a single lcd 2 fan controller for like 20 bucks. the lcds are nice since they have a temp monitor you can place and set it so it speeds up and down automatically
m
l
