Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > AMD Radeon > ATI 5770 + Nvidia 8800GTS, trying to test if physx work! HELP
Forum Graphics & Displays : AMD Radeon ATI 5770 + Nvidia 8800GTS, trying to test if physx work! HELP
HI,
I just did the trick using Phys mod 1.02 to get nvidia to enable physx in the nvidia control panel, but when I try to use FluidMark to test it.. my system keep crashing and reboot.. Furthmore, I tried clicking in FluildMark "Display Physx Properties," but nothing show up.
I have even tried GeeXLab and it does the same thing, crashed my computer and then reboot.. can anyone help plz..why I can't run test or why it keep crashing?
Reply to Anonymous
Are you using Windows 7, I think it is not possible to have 2 video drivers on any other OS.
Reply to paperfox
Hi,
I am currently using Window 7 x64 bit and I believe you can do ATI+ nvidia as physx on it..
I installed the latest driver for my ATI 5770 and driver 196.21 for my nvidia gts8800.. I checked nvidia control panel and it showed physx "enabled." Problem is I'm trying to test if it is indeed running as a physx with my ATI 5770. But everytime I test it on FluidMark I get system crash and then rebooted...
Reply to Anonymous
Perhaps you will have to use one of the older 186.## drivers.
Reply to paperfox
FluidMark NEVER worked for me when I tried it with my 4830/9500GT combo (now 5870/8800GT, still doesn't work). However, any other program or game I've tried has worked perfectly. Batman: AA has full PhysX acceleration and 3Dmark Vantage confirms it is active as well.
Try another program.
------------------------------ i7 2600K 5GHz w/HT 1.4v ~ Asrock P67 Fatal1ty ~ ASUS 6970 2GB 1000/1475 1.25v
16GB G.Skill Ripjaws X DDR3-1600 ~ Intel 160GB G2 SSD ~ OEM 8800GT PhysX ~ Samsung 12x Blu-ray
Seasonic X650 Gold ~ Razer Mamba & Lycosa ~ Tecnofront HWD ~ Big Custom Water
Reply to jedimasterben
- 0 +
Yes, DL the Batman: AA demo if you don't have the game;
http://www.batmanarkhamasylum.com/demo
Reply to jyjjy
There are 1527 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Upgrade from GTX260
By coffeecoffee, 7 hours ago:
 I think a 6850 would be the "near" perfect solution to your problem, I...
Best offers
Top experts
