Hello,
I put together a home build yesterday roughly based on the non-gamer build posted here:
http://www.tomshardware.com/forum/269162-31-recommended-builds-usage
The case suggested was out of stock, so I went with the following:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119203
Everything started fine, I installed Windows and have been working on the machine with no problem.
However, I attempted to plug in a wireless keyboard/mouse connector to the USB input on the front of the case. Occasionally when I did this, the machine would either turn on (if it was off) or turn off (if it was on).
I'm obviously thinking there is a short somewhere, but I'm not sure how to determine where. It doesn't happen if I unplug the USB from the MOBO. I tried switching to a different USB set on MOBO and the same thing occurred.
Any ideas on how to track down the problem?
