Hey guys, I'm trying to do a fresh install of XP after formating the HD and I'm running into a brick wall. My system was running just fine until it started getting very slow and throwing all sort of errors. Ran through the evet logs and traced it back to a bad Windows Update that didn't install properly. The system became so unstable that I had to use Ubuntu to get past the endless, Windows XP screen, BSOD, reboot, repeat cycle.
I formated the hard drive via Ubuntu and then rebooted with the Windows XP disc in (full version of Home) and the setup began. After it loaded I selected install and it came back and said it couldn't detect my hard drive!!! I ran the check disc utility in BIOS and it came back and said "#1 07 Fail" I honestly can not believe that my hard drive died. Its a WD 120 GB Scorpio Blue and is maybe one year old.
I can't access a single thing unless I load Ubuntu from the CD.
System is an HP DV9000 Pavillion laptop. HP support is BEYOND useless...
Any and all help is appreciated.
-Mike
PS. I downloaded the WD Data Lifeguard Tools for my hard drive and selected the version for DOS (CD) and burned it succesfully to a disc. Upon booting with said disc it comes up and says it can not located the license agreement.txt file. I have verified that the the txt file IS on the disc and I can oen it and read everything. WTF?!
I'm ready to take the laptop to a shooting range and use it for target practice
-Mike
