Yes No
Ads
HD5850 problems
Forum Graphics & Displays : Graphics Cards HD5850 problems
Hello,
i am having problems with my new graphic card. when i play direct x10 games my screen turns black and i have to restart manually. Also when watching fullscreen videos on youtube the same thing happens.
Does anyone have any advise??
Reply to yzaken
do you have the latest driver/hotfix? It may help:
http://support.amd.com/us/kbarticl [...] tions.aspx
It sounds like a slightly different issue, but I would not count out a sub-par driver.
If you have not already done so:
uninstall your driver, run driver sweeper, and reinstall hotfix.
If its something else, may have to dig deeper.. keep us posted
Edit:
Also if you could give your hardware/system info it might help.
Message edited by rmerwede on 02-10-2010 at 07:43:00 PM
Reply to rmerwede
- 0 +
Prossesor: intel core i5 cpu 750 @2.67ghz(4CPUs)
Memory: 4gb corsair ddr3
Case: Antec 300
Video Card: Hd 5850 Asus
Power supply: Antec True Power 550W
Motherboard:Gibabyte P55-US3L
Reply to yzaken
- 0 +
I ran driver sweep and reinstalled the driver that you gave me and it didn't work. I don't know what to do! Is there anything else?
Reply to yzaken
I had just bought sapphire hd 5850 and I have a couple of questions. Why does the driver suck? CCC or Catalyst Control Center is really horrible.. I know the card is pretty new so are they going to make a better driver soon? Also if i close the driver off my tray would that make my gaming better or would the driver still be used? Should I install the driver off the cd or off the site? I did both and they were both the same thing atleast that's from what i can tell.
Also I don't know if this is the video card's problem but i've been getting a lot of lag in my games. The net graph from cs1.6 shows that i get 0 choke and then it jumps to 35 when there's ppl on my screen also some 1 or 2 loss. And in sf4 even in trainingmode which is not online, the animation moves a lot slower like a couple of miliseconds after my inputs which I had never had this problem with my 8800gt.
Am i setting the drivers wrong? What settings should I be using?? The graphics are really good tho, youtube videos look hd which is amazing.
Sorry for the load of questions but I need helppp could there be a bottleneck somewhere?
Reply to Slim Shady
yzaken wrote :
Hello,
Hey I just recently built a core i7 860 build and got a 5850 to go along with it. First day in windows 7 I noticed that whenever I would go to watch a YouTube video, play a game, or come out of sleep mode my computer screen would go black.
You need the Hot Fix it will fix everything.
http://support.amd.com/us/kbarticl [...] otfix.aspx
If you are worrying don't. It's a common problem... Just make sure you download and install this for your version of windows.
cheers. :D
Reply to Butters088
If the above does not work try flashing your bios on your motherboard to the latest.
I have a GIGABYTE P55A-UD3 and also flashed them to version : F4 at the same time as the hotfix but I'm pretty sure the hotfix is what fixed it. gl
Reply to Butters088
- 0 +
i downloaded and installed the hot fix and i still have the problem. How do i flash my bios??
Reply to yzaken
Have any of you seen or tried this?
http://www.tomshardware.com/forum/280974-33-radeon-5700-5800-series-real-hotfix
Message edited by Mousemonkey on 02-11-2010 at 01:52:38 PM
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
ok I saw that you said u had a GIGABYTE P55A-US3L
but I think you meant UD3L.. anyways the latest bios can be found here if you have the GA-P55-UD3L if not just go to previous page and you can find the other models. http://www.gigabyte.us/Support/Mot [...] uctID=3169
I used the bios update tool from their site too to flash them. It was really easy compared to what I was expecting. It is called @BIOS.
It is the 7th one down on this page. http://www.gigabyte.us/Support/Mot [...] _List.aspx
Just install the program and select the bios file you downloaded from the first link (dl the F4 version its the latest.) I did these steps in order....
1)Uninstalled graphics drivers for HD5850
2)Flashed BIOS to version F4
3)Re-installed latest catalyst drivers from ATI's site.( v9.12 I think )
4)Installed Hot-fix and then everything worked. No more black screens from YouTube or gaming. Hope this helps just keep us posted.
Reply to Butters088
Oh and there is a quick and easy way to SAVE your previous version of your currently working bios on the tool I believe. Do that too.
Reply to Butters088
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > HD5850 problems
There are 1544 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Upgrade from GTX260
By coffeecoffee, 7 hours ago:
 I think a 6850 would be the "near" perfect solution to your problem, I...
Best offers
Top experts
