Running motherboard without battery
Hello,
can my cpu work without battery
1 answer Last reply
More about running motherboard battery
  1. Yes. The battery was mainly put in place to keep the BIOS settings in place if there was now power to the mobo.
    So for example, if your PC has no power due to it being unplugged or a power outage, the system will reset the BIOS.
    Other than that its not a needed thing unless you live in a consistent blackout area of California.
CPUs Battery Motherboards
