G
Guest
Guest
Hi guys,
I really need some major help please. I currently using WIndow 7 x64bit, have ATI 5770 and put nvidia 8800gts as my second slot. I applied the trick using Phys X mod 1.02 to allow nvidia control panel to enable "Physx" on. It worked, I enabled it.
PROBLEM IS: when I test it using FluidMark or any other kind of physx testing program to see if physx is working..everytime I load the test on any of the programs my system crash.. displaying blue screen error and that system need to be reboot to prevent hardware failure.
If anyknow can help whats the reason why... I tried playing Crysis and Left 4 Dead 2 in maxed setting, everything is fine, but then again those games don't require Physx.
