Case Modding/Building
I am in drastic need of help!!!
I would like to get into case modding, however i would like to design and build cases fom scratch. Is there any supplier in South Africa, that sells the components used for manufacturing cases EG: MB Back Plates, Case Frame Components and Case housing Components, I have searched the net eagerly and to no avail, have only come up with case modding...
Your Help will be much appreciated
Brandon Downs
1 answer Last reply
More about case modding building
  1. There's a guy in China I could hook you up with, but MOQ's are probably much higher than what you want to spend, unless you're going to be building 50 cases a year. You could always buy (or get for free) some old PC parts and salvage some chassis pieces and frankenstein something together though. Try craigslist for stuff like that.
New Build Cases Components Modding Systems
