Hello,
I was going to see if anyone had ran into a similar problem. Basically the stock self-contained water cooler fans that comes with the AMD FX-8150 don't work when plugged into the CPU_FAN (4-pin) header on my motherboard (please see specs below). The fans do work when plugged into the PWR_FAN (3-pin) header.
Here is the weird thing:
Both fans for the water cooler are 4-pin and are essentially hooked up to a splitter that combines them into a single 3-pin connection (this is required by the water block). I plugged in the 3-pin connection into the PWR_FAN header and it works just fine. I plugged in a 240mm fan (3-pin) into the CPU_FAN header, it works just fine. So both fans work, but it appears that the CPU_FAN header can't push two 120mm fans, but it can push a single 240mm. Anyone ran into this type of issue? I would prefer to tie the cpu fans into the CPU_FAN header for better monitoring reasons since the BIOS pulls different metrics from this header in comparison to system fan headers. I'm wondering if it has anything to do with the dynamic between the 4-pin header and the 3-pin connection of the splitter.
Mind you this a new build with no OS or BIOS updates (will try that later).
AMD FX-8150 Black Edition (3.6 GHZ) Case
Gigabyte GA-990FXA-UD3 Motherboard
Antec TPQ 1200 watt PSU
Cooler Master HAF 932 Advanced Case
16GB G. Skill Sniper Series 1866B
256GB SSD and 1TB HDD
Thanks!
Thanks!
