Monitor CPU temperature GA-MA770T
  • FIC
  • Monitors
  • CPUs
  • Temperature
  • Motherboards
October 4, 2010 8:57:00 AM
Hello,
I have an alarm coming from my mobo which appears to coincide with busy processor, so first assumption is CPU temp. Is there a way I can monitor this temperature whil running, or do I have to reboot and look through the BIOS, which means the system could cool in the meantime?
Thanks for all help
Jon
More about : monitor cpu temperature ma770t
October 4, 2010 12:04:31 PM
Thanks for your help. Someone else also referred me to a utility freeware called speedfan, which has been very helpful.
Incase it is of use to anyone else, I have also now discovered that the acceptable operating temperatures vary widely for different CPU's. My system was beeping because I had the monitor setting in the BIOS set lower than appropriate for the Athlon CPU.
So I can safely set it higher now that I know.
