Hey, I'm moving from Canada, (AC 120v 60Hz) to New Zealand (230v 50hz) and will be taking my monitor (AC 100-240v 50/60hz), will it be able to work with just a regular plug adapter? the voltage change is quite a lot which is why I'm asking.
As long as you have the right plug adapter it should work just fine. All the electronic devices that I've tried overseas rated at 100-240v worked with a simple adapter.
