Need advice on motherboard,cooling and case
APPROXIMATE PURCHASE DATE: (e.g.: this week (the closer the better)) BUDGET RANGE: £1700
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming,More Gaming,Movies
PARTS NOT REQUIRED: keyboard, mouse, monitor
PREFERRED WEBSITE(S) FOR PARTS: overclockers.co.uk scan.co.uk COUNTRY OF ORIGIN: (e.g.: Uk)
PARTS PREFERENCES: Cpu Intel i7 920, Graphics XFX ATI Radeon HD 5870,full Tower gaming case
OVERCLOCKING: Yes SLI OR CROSSFIRE: Yes (in the next 6 months)
MONITOR RESOLUTION: current monitor is 1680x1050 (but in the next 2 months i will be buying 3 x (1920x1200) new monitors (so if you have any suggestions on good Triple display monitors please comment
ADDITIONAL COMMENTS:
i have a few questions,worries
1.the Asus Rampage II Extreme motherboard is BIG and im worries that it might cause problem fitting and keeping good airflow also is this motherboard that good for pro/price or should i go for Gigabyte GA-EX58-Extreme Intel X58
2. Cpu cooler should i get Prolimatech Megahalems Or H50-1
3. also any other feed back and suggestions would be great
4. this will be my 3ed rig am going to be building
below is an example of the setup im going to be using
Combo Deal
http://www.overclockers.co.uk/showproduct.php?prodid=BU-045-OE
Graphics
http://www.overclockers.co.uk/showproduct.php?prodid=GX-147-XF
SDD
http://www.overclockers.co.uk/showproduct.php?prodid=HD-007-KS
Power supply
http://www.overclockers.co.uk/showproduct.php?prodid=CA-040-OC
Case
http://www.overclockers.co.uk/showproduct.php?prodid=CA-102-AN
HD
http://www.overclockers.co.uk/showproduct.php?prodid=HD-080-SA
Memory airflow
http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-CS
DVD Drive
http://www.overclockers.co.uk/showproduct.php?prodid=CD-039-OT
7 answers Last reply
More about need advice motherboard cooling case
  1. Note - The bundle operates above manufacturer specifications, as such it requires a quality power supply to operate with guaranteed stability. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range.
    I think u need to look at Corsair Psu,A CORSAIR CMPSU 850TX{They recomend quality brand psu,So a corsair)
    When coming to motherboard and cooling you have a good case with excellent cooling ,I think everything is fine except the psu due to their conditions of warranty and as ststed above!
  2. yea i did notice and i will be ringing them to confirm IF that is classed as a quality brand PSU since i know THEY might not class it as a quality brand psu
    also what do you think about fan's/cooling/water cooling
    for basic fans should i get 2/3 Noctua NF-P14 FLX Vortex-Control
    and for the Cpu fan/cooling should i get
    Prolimatech Megahalems Performance CPU Cooler
    Thermalright TRUE Copper CPU Cooler
    Corsair H50-1 High-Performance CPU Watercooler
    because of the very high overclocking i want to make the case as cool as possible
  3. bump
  4. I think this cpu cooler is good for i7
    CORSAIR Cooling Hydro Series CWCH50-1 120mm
    ,I had seen many i7 oc @4GHz stay cool with this and get some 120mm case fans from scythe like the Scythe SY1225SL12SH 120mm ,which has 110cfm(not sure.something like that) and these things will definitely cool ur pc very well!
    Wat abt getting Samsung Spinpoint F3 1TB 7200RPM? than a 5400rpm 1.5tb
  5. many air coolers are available which gaves more perfomance than this liq cooler,U can look at ZALMAN and NOCTUA
  6. yes today iv spent looking deep into liquid cooling and yes it does work and yes it looks great but still not worth the effort for reward factor
    as for extra fans i v got 2 x Scythe S-FLEX 1200RPM Ultra Quiet for push/pull combo with h50-1 cpu cooler
    Total : £1,808.21
    money goes to fast i need another 1800 for 3 x monitors and another 5870
  7. ok :)
New Build Monitors Systems Product
