I need help with order of the parts of should for my i7 930 build
just started my gaming build by buying the motherboard first the asus rampage gene 2 and now i am having second thoughts because if it fails then i wont be able to take it back to get a better board(15 day return policy) so if i take it back and use that $236 to get the smaller parts first(ram,hard drive,case,etc..)then get the motherboard and processor last so i can have more time to take it back if it doesnt get the job done or fails completely.. some parts advice would be great too $1000 max budget
4 answers Last reply
More about order parts build
  1. To save some time for people asking what it is you actually need, resolution of monitor, what parts you have already, if any, please repost using this format.
  2. That's a mini ATX MoBo intended for small cases for LAN parties....it's also quite long in the tooth.
    Start w/ one of these and modify as you go along:
    http://www.tomshardware.com/search.php?s=%241000
  3. what resolution are you playing at? (what size monitor) and I am assuming you are gaming with this system? what do you need? all parts? or do you have some stuff already (like monitor/keyboard/mouse/operating system)
    i7 930.............................$250 or so
    1366 motherboard.......~$200
    ram.................................$150
    case...............................$100
    Power Supply.................$100 for upper tier
    DVD drive........................$30
    Videocard.......................$100
    for $1000 you get the above with tax and shipping...the videocard would suck at $100...but you could upgrade later to a better videocard. For $100 you could get a Nvidia 9800GTX on sale and use it for 6 months...then upgrade to a fermi or a 5870 then for $400.
  4. The only thing I have right now is the motherboard which is asus rampage gene 2 I read some reviews and most of them are saying they have had boot problems and the north&south bridge heat up to 65c(I'm assuming that's too hot)so I don't wanna take chances if I can't take it back
Build Intel i7 Motherboards Systems
