hi im wondering if with a 500w power supply i can run a 250GTS...thanks hernan
hernan9999 Distinguished Feb 6, 2010 65 0 18,630 Feb 12, 2010 #1 hi im wondering if with a 500w power supply i can run a 250GTS...thanks hernan
S shadow187 Splendid Sep 16, 2009 4,103 0 23,160 Feb 12, 2010 #2 If that 500W psu has more than a total of 25A on the 12v and has an efficiency of above 75%, then you're good-to-go.
Derbixrace Distinguished May 26, 2008 1,283 0 19,360 Feb 12, 2010 #3 yes im 100% confident that it will run just fine
Derbixrace Distinguished May 26, 2008 1,283 0 19,360 Feb 12, 2010 #4 shadow187 : If that 500W psu has more than a total of 25A on the 12v and has an efficiency of above 75%, then you're good-to-go. lol we posted at the same time shadow
JackNaylorPE Titan BANNED Oct 30, 2004 32,255 14 99,960 Feb 12, 2010 #5 Let this "do the math" for you http://www.antec.outervision.com/ 1 GB 250 need about 69 watts for itself.
hernan9999 Distinguished Feb 6, 2010 65 0 18,630 Feb 12, 2010 #6 If that 500W psu has more than a total of 25A on the 12v and has an efficiency of above 75%-->in english...if i had a good performing power supply i wont´ve any problems???
S shadow187 Splendid Sep 16, 2009 4,103 0 23,160 Feb 13, 2010 #7 If that PSU is from a case, in other words, you didn't buy it yourself, then I'd be a little sketchy. JackNaylorPE : Let this "do the math" for you http://www.antec.outervision.com/ 1 GB 250 need about 69 watts for itself.
