Speedstep seems to stop working when resuming from sleep mode, at which point I'm stuck at 21x, which means turboboost is stuck ON since the default multiplier is 20x. So yeah, even with a cpu load of under 1% I'm stuck at 21x, & I don't need that!
I have an i5 750.
On a fresh boot up (windows 7, MSI P55-GD85), EIST & Turboboost work just fine. I can see the multiplier usually well under 20x & fluctating as needed (working as it should).
Anyhow, I'm not gaming all the time, so I definitely don't need a 21x multiplier going 24/7. And I do use sleep mode several times during the day & am definitely into power saving, all the more reason why I would like EIST & Turboboost to work properly when resuming from sleep.
I have the newest bios for my mobo, all the latest drivers & windows updates.
How do I go about troubleshooting this problem & keeping Speedstep, which is a must? Is this a common problem?
Thanks!
I have an i5 750.
Thanks!
