Closed Solved
Custom water cooling or Closed Loop ????
Hey guys , I'm really stuck between cooling for the fx 8350
should I go for a xspc raystorm 750 rs240
or
antec kuhler h20 920 or corsair h100
I want something that offers good cooling performance , durable , easy to maintain and also ,not too costly.
5 answers Last reply Best Answer
More about custom water cooling closed loop
  1. Best answer
    You'll get better temps with the xspc kit. Will you ever need to move this pc? The closed loop would be the easiest to maintain. You won't need to do anything other than take the fans off and spray compressed air to remove dust. The xspc kit will need to be drained and refilled. It all depends on what you're willing to do.
  2. The xspc kit might be a problem ...I've heard custom loops need to have kill coils ,distilled water , need to be checked every 3-6 months , chances of leaking and all...so I don't really know
    The antec has a very nice LED , USB controllable fans ,pump speeds ,temp monitoring .......
  3. I would strongly encourage everyone to read through the watercooling sticky at the top of the watercooling forum. It addresses every single question/suggestion listed here.
  4. Best answer selected by compgenie.
  5. This topic has been closed by Rubix_1011
Water Cooling Cooling Overclocking
