Problem building PC
I connected up a Gigabyte GA-8GVMT 4 Motherboard, when I turn on pc the green light on monitor turns orange, then I saw there where no jumpers set, can you please tell me which must be set and the settings.
1 answer Last reply
More about problem building
  1. Eh? Well, it sounds like you're getting no video signal. My guess is that you've got the monitor plugged into a video card, but the onboard graphics on the motherboard are still enabled. That can be fixed by just turning them off in the BIOS; the video card should work then.
    Or, if you're not using a video card, you could have the onboard graphics disabled in the BIOS. Doing a CMOS clear by removing the battery should fix that.
    Of course, these are just guesses, but without more information, that's all anyone can do.
Homebuilt Motherboards Systems
