Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > GA-EP45-UD3P Ethernet Problems
Forum Motherboards & Memory : Gigabyte GA-EP45-UD3P Ethernet Problems
I have been using this board for some time. The one thing that i am very unhappy with is the Dual ethernet ports. I have installed all the latest drivers, but when i plug two cables into my machine, and set them as a conjoined connection in the diagnostics, i always get a BSOD. :pfff:
I just finished a fresh install of vista 64 bit in raid0. Any tips on how to get this network issue solved would be greatly appreciated.
Thanks,
Joe
SPecs:
4870 (1gb) x2
Dual core 3.0 ghz
4 gigs ram
GA-EP45-UD3P
Reply to Zoke
Welcome Newcomer! :)
Are you Bridging, Teaming, or Sharing the NICs? They are all different and all set-up differently. In most "home" environments the Teaming will not work {home routers do not support that feature} and Bridging is unnecessary in 99% of broadband situations. Therefore, Sharing (i.e. LAN Party) is about the only useful situation.
I would strongly recommend that you use the Realtek Ethernet Diagnostic Utility to set-up your NIC. I reviewed the Manual an there is a very good guide on page 84 for "Teaming." Teaming is good for redunancy and doubling the bandwidth, but keep in mind if there is not other PC/Server on your network it will be as fast as the slowest connection(s). Example, if your Router is 10/100 and another PC has a 1000 port the speed will be 100 -- if connecting to a PC with Team 1000 port then 200 will be the limit, etc. Further, if the purpose is to "improve" your internet connection then it will not; FIOS offers {50 Mbps X 0.125 = 6.25 MB/s} 6.25 is crazy slow compared to 100/1000/2000.
Further, my experience with Dual NIC is not to "Bridge" via Windows; Realtek & Intel have their own implementation which "may" explain your problem.
Examples:
Intel - http://www.intel.com/support/network/sb/CS-009747.htm
Realtek - {see your manual}
Reply to jaquith
There are 1828 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Do I need a new motherboard?
By smorizio, 4 hours ago:
you waste your money unless you where getting an overclock cpu. any new mb with the same...
Best offers
