Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] Power supply recommendations
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] Power supply recommendations
Best answer from JohnnyLucky.
I am looking for a power supply recommendation for the following system: Rosewill CRUISER Black Gaming ATX Mid Tower ASUS M4A89GTD PRO AM3 AMD 890GX AMD Phenom X2 545 Using on board graphics CORSAIR XMS3 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Any help would be appreciated.
Reply to tsburdette
500w should do. get a good one like corsair psu
some may say lower but this will be ok even when u update your pc.
Reply to robin banks uk
+1 to the first reply. You could get away with a 400W PSU using onboard graphics, but a 500W would give you more scope in the future if you ever did want to upgrade. See how the budget stretches. I do believe Antec do a 380W Earthwatts PSU which is a great PSU and at a good price which would be enough for your needs. Corsair, Seasonic and the newer Antec models (like the Earthwatts) are the brands you want to be looking at. Good luck!
------------------------------ Troubleshooting Overheating Issues & Maintaining A Cool System
Reply to moody89
Best answer
The general rule of thumb is a high quality 500 to 550 watt power supply with sufficient current (amps) on the +12 volt rail(s) can easily power a system with any single video card made. A high quality 700 to 750 watt power supply with sufficient current (amps) on the +12 volt rail(s) can power a system with two video cards operating in dual mode. There are a few exceptions like the new ATI Radeon HD 5000 series cards which use less power due to their energy efficiency. On the other hand the top of the line 5970 video card and the new Nvidia Fermi use more power.
A high quality 500 to 550 watt psu will have a +12 volt rail rated at 40 amps. A high quality 700 to 750 watt psu will have a +12 volt rail rated at 60 amps.
In addition the power supply should be at least 80+ Bronze certified for energy efficiency. There are some models available which have achieved 80+ Silver and 80+ Gold Certifications.
Before purchasing a new psu you will need to decide whether you will eventually have a pc with one or two video cards.
Corsair and Seasonic are two brands that have a reputation for high quality power supplies that consistently earn high marks in technical reviews. They are reliable, stable, and come with a 5 year warranty. Some of the newer models come with a 7 year warranty. In addition, some of the newer models have earned a gold certification for energy efficiency.
Lately we've been seeing a few other brands offering some high quality units. One example would be the Antec Earthwatts and the Antec TruePower New series which are major improvements over Antec’s older psu’s like the Basiq models.
Message edited by JohnnyLucky on 05-02-2010 at 04:27:06 PM
Reply to JohnnyLucky
There are 1817 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 4 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
