Sign-in / Sign-up
Solved
Help hd stops after few seconds
  • Hard Drives
  • Western Digital
  • Storage
Last response: in Storage
March 4, 2012 4:09:00 PM
hi
my hard disk western digital caviar 1tb, switches off after a few seconds of being powered.
it is not detected in bios obviously
can't boot
can't do nothing
it starts then stops after about 15 seconds
u can hear it powering on , turning, click, stop... dead
i have tried to unplug both cables(power and sata) and starts the same cycle powers, disc rotates a few seconds , click and stop
i have tried on different computers and it is always the same
i can't open it cos i dont have the right screwdriver
anyone knows how to fix it or is it dead?
thank you all
More about : stops seconds
Best solution
March 5, 2012 9:19:21 PM
sounds like its dead, either the heads are damaged or stuck, indicated by the click and then stoping.
2 ways i know to solve this temporarily(you will need to replace the drive)
if you need/want to recover data theirs 2 things you can try.
1: The freezer: take the HDD out and wrap it in cling film or a zip lock bag, get as much air out as you can before you seal it and place it in a freezer over night. this will cause the heads to contract and possibly un-stick them long enough to recover any data.
2: put the drive on its side, turn on, doesnt work? put drive upside down, turn on........vertical and so on until it works. usually a certain possition will allow a stuck head to dislodge itself.
iv got a 500g hdd that only works when its layed on its back lol
March 16, 2012 7:44:38 AM
Best answer selected by piego59.
m
l
