Sign-in / Sign-up
Solved
Need wireless network card for homebuilt pc
  • NICs
  • Wireless Network
  • Wireless Internet
  • Homebuilt
  • Components
  • Product
Last response: in Components
May 1, 2010 3:38:32 AM
Alright I need a wireless internet card for the pc I am building and would appreciate some help. can someone suggest a wireless card for my desktop? price range is around 30 -50$? I dont want any lag on web browsing or gaming , thanks :)  If you want or require my build or any other information just ask in the post and I will supply it
More about : wireless network card homebuilt
a b B Homebuilt system
May 1, 2010 4:15:15 AM
what kind of wireless router are you connecting to(N, G, B)?
m
l
May 1, 2010 9:10:07 PM
I have an N router
m
l
May 2, 2010 11:12:30 PM
Lutfij said:
linksys and netgear manufacture wireless lan cards for a reasonable price and give you good throughput in data :)
but i dug this up in newegg ; http://www.newegg.com/Product/Product.aspx?Item=N82E168...
and heres the search page in case you'd want t see cards that are between two pc's
http://www.newegg.com/Store/SubCategory.aspx?SubCategor...
Thanks, The reviews say Its not very compatible with windows 7 ( my OS ) so im kind of skeptical, but ill look on the second link you gave me , once again thanks :)
m
l
May 3, 2010 4:12:37 AM
ahhh thank you EMERALD :)  that card seems PERFECT .. very much appreciated :D
m
l
May 3, 2010 4:14:26 AM
Best answer selected by adam873873.
m
l
