Hi,
I purchased a Radeon 5770. Stupidly, I forgot to check and make sure my power supply is compatable.
It turns out that my power supply does not have a 6-pin PCI-Express connector.
However, a slip of paper came with my card that appeared to claim it can be used with a variety of pins including 1x4.
If I plug a 4-pin connector to one of the rows 3-pin rows (So one pin sticks out) will the card work?
Can doing so cause damage to my power supply?
If not, will a 4-pin to 6-pin adapter from somewhere work so I don't have to pay for a new power supply?
Also, on a different note:
Should a 550-watt power supply be able to handle an AMD Athlon II x4 620, 4gb DDR2-800 and a Radeon 5770?
