Closed Solved
First build, Found what I THINK I need, what do you think?
This is my first build, I'm doing it with a friend thats a computer GURU, problem is, he has a bottomless pit of money. He put together a computer, but it was more then I was originally going to spend. So I went ahead and tweaked it. I'll post both so you guys can tell me what I should go with.
My main use of the system would be: CAD design software, Internet, Gaming, movies.
Please feel free to make any changes. Both computers are in my range, but at either end. 1300-1600.
These machines where put together through the newegg site, which I prefer to use.
Machine Number 1 $1600 range.
Rosewill CRUISER Black Gaming ATX Mid Tower Computer Case with Side Panel Window and Four Fans - Retail
Model #:Cruiser
Item #:N82E16811147145
GIGABYTE GA-EX58-UD3R LGA 1366 Intel X58 ATX Intel Motherboard - Retail
Model #:GA-EX58-UD3R
Item #:N82E16813128375
Intel Core i7-920 Bloomfield 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail
Model #:BX80601920
Item #:N82E16819115202
SAPPHIRE 100283-2L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - Retail
Model #:100283-2L
Item #:N82E16814102864
Rosewill Xtreme Series RX850-S-B 850W Continuous @40°C ,80 PLUS Certified, ATX12V v2.2 & EPS12V v2.91, SLI Ready CrossFire ... - Retail
Model #:RX850-S-B
Item #:N82E16817182072
G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model F3-16000CL9T-6GBRH - Retail
Model #:F3-16000CL9T-6GBRH
Item #:N82E16820231306
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:WD1001FALS
Item #:N82E16822136284
SAMSUNG Black Blu-ray Combo Drive - Bulk SATA Model SH-B083L/BSBP LightScribe Support - OEM
Model #:SH-B083L/BSBP
Item #:N82E16827151199
COOLER MASTER Hyper 212 Plus Intel Core i5 & Intel Core i7 compatible RR-B10-212P-G1 120mm "heatpipe direct contact" Long ... - Retail
Model #:RR-B10-212P-G1
Item #:N82E16835103065
Rosewill RNX-G300LX IEEE 802.11b/g PCI Wireless Card Up to 54Mbps Data Rates 64/128-Bit WEP, 802.1x, WPA, WPA2, AES, TKIP ... - Retail
Model #:RNX-G300LX
Item #:N82E16833166021
ASUS VW246H Glossy Black 24" 2ms(GTG) HDMI Widescreen LCD Monitor - Retail
Model #:VW246H
Item #:N82E16824236049
OK..........NOW, for the one that I changed to save a little cash, if its really worth it..........or, if it'll even work, you let me know. Please help me get this figured out!!
Computer Number 2 $1300 range
Broadway Com Corp Runner Black SECC Steel ATX Mid Tower Computer Case - Retail
Model #:Runner
Item #:N82E16811162046
Model #:100283-2L
Thermaltake TR2 W0379RU 500W ATX 12V v2.2 Power Supply - Retail
Model #:W0379RU
Item #:N82E16817153113
Model #:BX80601920
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7D-4GBRH - Retail
Model #:F3-10666CL7D-4GBRH
Item #:N82E16820231276
Model #:WD1001FALS
Sony Optiarc DVD Burner with LightScribe Black SATA Model AD-7241S-0B LightScribe Support - OEM
Model #:AD-7241S-0B
Item #:N82E16827118032
Model #:RNX-G300LX
Model #:VW246H
Thanks for taking the time to skim through this. Any advice, or ideas would be greatly appreciated!!
4 answers Last reply Best Answer
More about first build found need think
  1. Best answer
    1. For an i7 CPU and a monitor that size, a 5770 is actually going to be a drag on the system. I'd recommend at least a 5850.
    2. On the first one: Rosewill power supplies used to have a reputation for being a POS. Don't know if they've gotten better, but I would still avoid.
    2a. On the second one, you'll probably want more than 500W to go with your new 5800 series video card
    3. On the second one, yes, 4GB of RAM is plenty for most purposes ... but since it's only an extra $20, it's worth getting 4GB of DDR3-2000 instead of DDR3-1333.
    (edit: Just noticed CAD/graphic editing as a priority -- in which case, if you're working on large projects, more RAM helps).
    4. Do you really NEED a motherboard that costs $200? e.g. are you planning on upgrading the CPU to an i9 or higher in the future, which is what you would need a socket 1366 board for, or are you planning on crossfiring? If no to both, you can probably make do with a 1156 board for half the price. Also, you may want to investigate getting a motherboard with USB 3.0 support. You'll be glad a couple years from now.
    5. For 7200 RPM hard drives, I believe the Samsung Spinpoint is the one everyone raves about, and is actually slightly cheaper than the one you picked. The Seagate Barracuda also comes pretty well recommended.
  2. power supply - go with either corsair, ocz, or thermaltake!!
    CPU- budget computers should go with amd, games are not usually cpu dependent,with the money you save by going amd you could get an HD5870 instead of a 5770!!!
    Ram- Check this ram out they are great!!!
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820211409&cm_re=adata_ddr3-_-20-211-409-_-Product
  3. Best answer selected by mousemonkey.
  4. This topic has been closed by Mousemonkey
Homebuilt Systems Product
