It's my first time building a PC, and I'm having some trouble deciding how powerful the PSU should be and could use some help.
These are the components I've picked:
Mobo: Asus M4A79XTD EVO http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131402
CPU: AMD Phenom II x4 3.2GHz BE http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103808
GPU: HIS Radeon HD5770 1GB http://www.newegg.com/Product/Produ..._-Hightech+Information+System+Ltd.-_-14161317 (this one on Newegg aint exactly the same as the one I've chosen, but the specs are more or less identical)
RAM: Kingston DDR3 HyperX 4GB 1600MHz http://www.newegg.ca/Product/Product.aspx?Item=N82E16820104141
HDD: Western Digital Caviar GreenPower 1TB http://www.newegg.ca/Product/Product.aspx?Item=N82E16822136490
Case: Cooler Master HAF 922 http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119197
I've been eyeing this 700W PSU from OCZ: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817341019 , but I'd like some input before I decide.
Thanks in advance!
Thanks in advance!
