Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] Power Supply Tester Results Confusing
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] Power Supply Tester Results Confusing
Best answer from .
I tested my mobo's 24 pin power connector with Antec's Digital PC Power Tester. It showed all voltages within normal range, but it showed the +12v2 as a flashing "LL" and was beeping. Is this an indication of a bad PS, or is it because the +12v2 isn't present in the 20+4 pin mobo connector?
My computer has been shutting down unexpectedly. Lately, it won't even start. Pressing the power-on switch does absolutely nothing. (Power-on Switch checks OK) Sometimes if I recycle pwr to the PSU, I can get a quick bump of fans and lites... then nothing. Occassionally, I can get it to start up and boot to Windows. But eventually it will turn off just like I pulled the plug.
PS = ePower EP-850 XP, 4 +12v rails
Mobo = Asus P5N-E SLI 650i
Btw, is it possible to insert pics in msgs in this forum?
Message edited by clutchc on 05-02-2010 at 03:28:19 AM
------------------------------ i5-2500K 3.3GHZ, Hyper 212 EVO, Gigabyte Z68XP-UD3P Board, 8GB 1333MHZ G.Skil Sniper, 2 x GTX 570 SC SLI, Crucial M4 SATA3 64GB SSD, WD 500GB HDD, X-FI Titanium, XFX 850W PSU, 32" @ 1920x1080
Reply to clutchc
Best answer
did you hook up the 4 pin 12 volt to the other side like you would on the mother board
Reply to Anonymous
Hi cletusheaps,
At first I had not. But after some further review, yes, I did. However, the problem has since been solved with a new PSU. All is well now. But thank you for the reply.
Reply to clutchc
Best answer selected by clutchc.
Reply to clutchc
There are 1933 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 4 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
