Using 32bit formated drive in 64bit systems
  • Hard Drives
  • Western Digital
  • Windows Vista
  • Systems
  • Storage
Last response: in Storage
March 6, 2012 8:47:19 PM
Hello,
I NTFS formatted a brand new WD 2TB drive and populated it with data using a Windows XP 32Bit system. The drive now had a remainder of 283GB useable. I hooked the drive up to a Windows Vista 64Bit system. Diskmanager shows the drive as healthy and the appropriate size. I was unable to access or view the data and a I/O error occured. Am I missing something, should I have initialized the drive when hooked up the Vista system?
Thanks in advance!
More about : 32bit formated drive 64bit systems
a b G Storage
March 6, 2012 9:46:59 PM
The OS (XP-32bit or Vista-64bit) should not make a difference.
however being your XP machine is older it may not be able to see such a large drive (motherboard limitation)
Try doing a bios update of the XP's motherboard.
m
l
March 6, 2012 10:33:12 PM
Actually check for bios update for the Vista64bit system..
m
l
