Hey all, sorry if this is in the wrong section butthis is my first time building a computer from scratch & I could really use a hand figuring this out.
Ok, here's a list of parts that I have - and i'll list what happens when I turn the computer on:
Motherboard: P6T6 WS Revolution (Not sure if it's damaged)
Processor: i7-920 2.66GHz - "D0"
RAM: Corsair XMS3 (3x 2GB sticks - one connected to A1 & B1, third not plugged in)
GPU: nVidia GTX 285
PSU: Hytec 1000w (Labeled TITAN)
Harddrive: 1TB Western Digital
CRT monitor hooked up to check
Keyboard connected
No mouse connected
Windows 7 Ultimate serial/disc (not installed)
#1. I turn on the Power. The CPU fan starts up; the SW_POWER green light turns on; sometimes the blue DIAG CPU led on the board flashes and stays off, sometimes it stays on; the green light inside of the GPU turns on but the fan doesn't move; Monitor displays 'No Signal' and stays black/goes to standby; the G.P. Diagnosis chip that came with the board displays F.F.
To me the processor looks absolutely fine, but the motherboard may have gotten dinged around a little during shipping -- The System Speaker does not beep at all, no matter what RAM combination I use or what sequence I put the parts in, it makes NO noise whatsoever. I'm guessing, but I think the motherboard doesn't like the processor.
I should also probably mention that the two Hard Drives are both blank and need an OS installed, I only have one hooked up. When I turn the power on the monitor just stays blank - and I cannot turn the computer off by holding the power button on either the computer case, or the G.P diagnosis chip - the only way to turn it off is the PSU on/off switch.. =/
Anyone smarter than me out there who has some idea on what's up with this thing?
GPU: nVidia GTX 285
Keyboard connected
No mouse connected
