Will this PSU work with my ECS motherboard?
Power Supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005&Tpk=corsair%20650tx
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135072&cm_re=ecs_915p-_-13-135-072-_-Product
i'm building a new cpu and i have the motherboard connected correctly but when i try to turn it on i get no response. i already did the paperclip test on my psu and it works well enough. right now i think its either incompatible or the case is faulty.
Case:
http://www.frys.com/product/6007768?site=sr:SEARCH:MAIN_RSLT_PG
2 answers Last reply
More about will work motherboard
  1. The motherboard requires two power cable connections. Do you have the smaller 4 pin power cable plugged into your motherboard?
  2. The case and the PSU seem fine, however that seems to be a pretty old motherboard model. Can you list your full system specs so we can get more info?
Power Supplies Cases ECS Motherboards Components Product
