So far so good.. taking it slow to make sure everything is right. Some stupid questions before I get to far.
Where the mobo goes there is a piece of paper like a template showing the holes where the mounting screws go. They are labeled ABCD ect. After I place the standoffs where they go do I leave the template or rip it out?
I have the cooler master case and it has the fancy slip in HD spots. You just insert HD into this bracket then slide it back in and snap the thing shut. Question is silver part of hd up or side with circuit board up?
Stay tuned for more questions. Oh and I'm assuming the fan on the Power supply faces down?
