Closed Solved
Need a Temperature Monitor
I have a Vista pc with a Pentium(R)4 3.2GHz processor (LGA 775 Prescott). I can find no temperature monitor that will work with this processor. Everest shows no temp, RealTemp says the processor is not supported and same for Speedfan. Whats the deal? They all work with the P4 3.4GHz Prescott. Anyone know of any that might work?
Thanks!
11 answers Last reply Best Answer
More about need temperature monitor
  1. Try CPUID's HWMonitor. It's a very handy utility and should work ok. Good luck!
  2. Nope, CPUID's HWMonitor only shows the HDD temp. In CoreTemp's README "-Pentium 4/D CPUs ARE NOT SUPPORTED!-"
  3. Intel Pentium 4 CPUs do not have any core temperature sensors (like Intel Core 2, i3/i5/i7 CPUs). So the only way to get some CPU temperature would be via some hardware monitoring chip on your mainboard.
    What mainboard do you have?
    You could give the the Open Hardware Monitor a try. But chances are not too great when HWMonitor can't find the anything useful.
  4. Like I said, they all work with the Pentium 4 550/3.4GHz I have. Thats part of the mystery. The board is a
    Dell 0G8310, Intel i915P/i915G chipset, Southbridge 82801FB (ICH6). The box with the P4 has an Asus P5AD2-Deluxe.
  5. Can you create a Report with the Open Hardware Monitor (using File -> Save Report...) with both your P4 systems and post them? Maybe I can understand a bit more in detail what is going on from them.
  6. Pentium(R)4 3.2GHz
    CPUID HWMonitorPro Report
    Binaries
    HWMonitorPro version 1.0.8.0
    Monitoring
    Mainboard Model 0G8310 (0x00000143 - 0x004D1800)
    LPCIO
    LPCIO Vendor SMSC
    LPCIO Vendor ID 0x55
    LPCIO Chip ID 0x76
    Config Mode I/O address 0x2E
    Config Mode LDN 0xA
    Config Mode registers
    00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
    00 00 00 00 00 00 00 00 0A 00 00 00 00 00 00 00 00
    10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    20 76 01 29 00 04 00 2E 00 00 00 00 00 10 00 00 00
    30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    60 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Register space LPC, base address = 0x0C00
    Hardware Monitors
    Hardware monitor Maxtor 6Y080M0
    Temperature 0 46°C (114°F) [0x2E] (Assembly)
    Processors
    Number of processors 1
    Number of threads 2
    APICs
    Processor 0
    -- Core 0
    -- Thread 0 0
    -- Thread 1 1
    Processors Information
    Processor 1 ID = 0
    Number of cores 1 (max 1)
    Number of threads 2 (max 2)
    Name Intel Pentium 4 540
    Codename Prescott
    Specification Intel(R) Pentium(R) 4 CPU 3.20GHz
    Package (platform ID) Socket 775 LGA (0x4)
    CPUID F.4.1
    Extended CPUID F.4
    Core Stepping E0
    Technology 90 nm
    Core Speed 3191.9 MHz
    Multiplier x FSB 16.0 x 199.5 MHz
    Rated Bus speed 798.0 MHz
    Stock frequency 3200 MHz
    Instructions sets MMX, SSE, SSE2, SSE3
    L1 Data cache 16 KBytes, 8-way set associative, 64-byte line size
    Trace cache 12 Kuops, 8-way set associative
    L2 cache 1024 KBytes, 8-way set associative, 64-byte line size
    FID/VID Control no
    Thread dumps
    CPU Thread 0
    APIC ID 0
    Topology Processor ID 0, Core ID 0, Thread ID 0
    Type 01001003h
    Max CPUID level 00000005h
    Max CPUID ext. level 80000008h
    Cache descriptor Level 1, D, 16 KB, 2 thread(s)
    Cache descriptor Level 2, U, 1 MB, 2 thread(s)
    Cache descriptor Level 1, T, 12 KB, 2 thread(s)
    CPUID
    0x00000000 0x00000005 0x756E6547 0x6C65746E 0x49656E69
    0x00000001 0x00000F41 0x00020800 0x0000441D 0xBFEBFBFF
    0x00000002 0x605B5001 0x00000000 0x00000000 0x007C7040
    0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
    0x00000004 0x00004121 0x01C0003F 0x0000001F 0x00000000
    0x00000004 0x00004143 0x01C0103F 0x000003FF 0x00000000
    0x00000005 0x00000040 0x00000040 0x00000000 0x00000000
    0x80000000 0x80000008 0x00000000 0x00000000 0x00000000
    0x80000001 0x00000000 0x00000000 0x00000000 0x00000000
    0x80000002 0x20202020 0x20202020 0x20202020 0x6E492020
    0x80000003 0x286C6574 0x50202952 0x69746E65 0x52286D75
    0x80000004 0x20342029 0x20555043 0x30322E33 0x007A4847
    0x80000005 0x00000000 0x00000000 0x00000000 0x00000000
    0x80000006 0x00000000 0x00000000 0x04006040 0x00000000
    0x80000007 0x00000000 0x00000000 0x00000000 0x00000000
    0x80000008 0x00002024 0x00000000 0x00000000 0x00000000
    MSR 0x0000001B 0x00000000 0xFEE00900
    MSR 0x00000017 0x00120000 0x00000000
    MSR 0x0000002C 0x00000000 0x10120210
    MSR 0x000001A0 0x00000004 0x208400C9
    CPU Thread 1
    APIC ID 1
    Topology Processor ID 0, Core ID 0, Thread ID 1
    Type 01001003h
    CPUID
    0x00000001 0x00000F41 0x01020800 0x0000441D 0xBFEBFBFF
    MSR 0x0000001B 0x00000000 0xFEE00800
    Graphic APIs
    API ATI OD5
    API ATI I/O
    Display Adapters
    Display adapter 0
    Manuf. API index 0
    Display name \\.\DISPLAY1
    Name ATI Radeon X300/X550/X1050 Series
    PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
    Vendor ID 0x1002 (0x1002)
    Model ID 0x5B60 (0x0402)
    Display adapter 1
    Manuf. API index 1
    Display name \\.\DISPLAY2
    Open Hardware Monitor Report
    Version: 0.1.33.0
    +-+ 0G8310 (/mainboard)
    +-+ Intel Pentium 4 3.20GHz (/intelcpu/0)
    | +- Load : 1 : CPU Core : 25.38414 : 5.384004 : 100
    | +- Clock : 1 : CPU Core : 3192.455 : 3192.455 : 3192.455
    | +- Clock : 0 : Bus Speed : 199.5284 : 199.5284 : 199.5284
    +-+ Maxtor 6Y080M0 (/hdd/0)
    | +- Temperature : 0 : HDD : 46 : 46 : 46
    Mainboard
    BIOS Vendor: Dell Inc.
    BIOS Version: A04
    Mainboard Manufacturer: Dell Inc.
    Mainboard Name: 0G8310
    LPCIO
    Chip ID: Unknown ITE with ID 0x7601
    Chip ID: Unknown SMSC with ID 0x7601
    CPUID
    Processor 0
    Processor Vendor: Intel
    Processor Brand: Intel(R) Pentium(R) 4 CPU 3.20GHz
    Family: 0xF
    Model: 0x4
    Stepping: 0x1
    CPUID Return Values
    CPU Thread: 0
    APIC ID: 0
    Processor ID: 0
    Core ID: 0
    Thread ID: 0
    Function EAX EBX ECX EDX
    00000000 00000005 756E6547 6C65746E 49656E69
    00000001 00000F41 00020800 0000441D BFEBFBFF
    00000002 605B5001 00000000 00000000 007C7040
    00000003 00000000 00000000 00000000 00000000
    00000004 00004121 01C0003F 0000001F 00000000
    00000005 00000040 00000040 00000000 00000000
    80000000 80000008 00000000 00000000 00000000
    80000001 00000000 00000000 00000000 00000000
    80000002 20202020 20202020 20202020 6E492020
    80000003 286C6574 50202952 69746E65 52286D75
    80000004 20342029 20555043 30322E33 007A4847
    80000005 00000000 00000000 00000000 00000000
    80000006 00000000 00000000 04006040 00000000
    80000007 00000000 00000000 00000000 00000000
    80000008 00002024 00000000 00000000 00000000
    CPU Thread: 1
    APIC ID: 1
    Processor ID: 0
    Core ID: 0
    Thread ID: 1
    00000001 00000F41 01020800 0000441D BFEBFBFF
    Intel CPU
    Name: Intel Pentium 4 3.20GHz
    Number of Cores: 1
    Threads per Core: 2
    TSC: Not Invariant
    Timer Frequency: 14.31818 MHz
    Max Clock: 3192.46 MHz
    MSR Core #1
    MSR EDX EAX
    00000198 00001025 00001025
    0000019C 00000000 00000000
    000001A2 00000000 00001268
    System.EntryPointNotFoundException: Unable to find an entry point named 'ADL_Main_Control_Create' in DLL 'atiadlxx.dll'.
    at PInvokeDelegateFactoryInternalWrapperType16.ADL_Main_Control_Create(ADL_Main_Memory_AllocDelegate callback, Int32 enumConnectedAdapters)
    at OpenHardwareMonitor.Hardware.ATI.ADL.ADL_Main_Control_Create(Int32 enumConnectedAdapters)
    at OpenHardwareMonitor.Hardware.ATI.ATIGroup..ctor()
    Core Temp
    SpeedFan 4.0
    P4 3.4GHz
    Core Temp
    Version: 0.1.33.0
    +-+ ASUS P5AD2-Deluxe (/mainboard)
    +-+ Intel Pentium 4 3.40GHz (/intelcpu/0)
    | +- Load : 1 : CPU Core : 20.3125 : 5.46875 : 55.55556
    | +- Clock : 1 : CPU Core : 3412.799 : 3412.799 : 3412.799
    | +- Clock : 0 : Bus Speed : 200.7529 : 200.7529 : 200.7529
    +-+ ATI Radeon X300/X550/X1050 Series (/atigpu/0)
    Mainboard
    BIOS Vendor: American Megatrends Inc.
    BIOS Version: 1007.008
    Mainboard Manufacturer: ASUSTeK Computer INC.
    Mainboard Name: P5AD2-Deluxe
    LPCIO
    Chip ID: Unknown Winbond / Fintek with ID 0x8853
    CPUID
    Processor 0
    Processor Brand: Intel(R) Pentium(R) 4 CPU 3.40GHz
    Family: 0xF
    Model: 0x3
    Stepping: 0x4
    CPUID Return Values
    CPU Thread: 0
    APIC ID: 0
    Processor ID: 0
    Core ID: 0
    Thread ID: 0
    00000001 00000F34 00020800 0000441D BFEBFBFF
    80000004 20342029 20555043 30342E33 007A4847
    CPU Thread: 1
    APIC ID: 1
    Processor ID: 0
    Core ID: 0
    Thread ID: 1
    00000001 00000F34 01020800 0000441D BFEBFBFF
    Intel CPU
    Name: Intel Pentium 4 3.40GHz
    Number of Cores: 1
    Threads per Core: 2
    TSC: Not Invariant
    Timer Frequency: 3412.15 MHz
    Max Clock: 3412.8 MHz
    MSR Core #1
    MSR EDX EAX
    00000198 0000112D 0000112D
    0000019C 00000000 00000002
    000001A2 00000000 00001048
    AMD Display Library
    Status: OK
    Number of adapters: 2
    AdapterIndex: 0
    isActive: 1
    AdapterName: ATI Radeon X300/X550/X1050 Series
    UDID: PCI_VEN_1002&DEV_5B60&SUBSYS_005C1043&REV_00_4&3943680D&0&0008A
    Present: 1
    VendorID: 1002
    BusNumber: 4
    DeviceNumber: 0
    FunctionNumber: 0
    AdapterID: 0x8A2D5078
    AdapterIndex: 1
    isActive: 0
    AdapterName: ATI Radeon X300/X550/X1050 Series Secondary
    UDID: PCI_VEN_1002&DEV_5B70&SUBSYS_005D1043&REV_00_4&3943680D&0&0108A
    Present: 1
    VendorID: 1002
    BusNumber: 4
    DeviceNumber: 0
    FunctionNumber: 1
    CPUID HWMonitor Report
    Binaries
    HWMonitor version 1.1.5.0
    Monitoring
    Mainboard Model P5AD2-Deluxe (0x000003D0 - 0xB547CCA0)
    LPCIO
    LPCIO Vendor Winbond
    LPCIO Model W83627EHF
    LPCIO Vendor ID 0x5CA3
    LPCIO Chip ID 0x88
    LPCIO Revision ID 0x53
    Config Mode LDN 0xB
    00 FF FF FF FF FF FF FF 0B FF FF FF FF FF FF FF FF
    10 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    20 88 53 FF 00 44 00 00 FF 50 04 00 00 98 21 00 FF
    30 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    40 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    50 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    60 02 90 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    70 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Register space LPC, base address = 0x0290
    Hardware Monitors
    Hardware monitor Winbond W83627EHF
    Voltage 0 1.37 Volts [0xAB] (CPU VCORE)
    Voltage 1 1.82 Volts [0xE4] (VIN0)
    Voltage 2 3.28 Volts [0xCD] (AVCC)
    Voltage 3 3.26 Volts [0xCC] (+3.3V)
    Voltage 5 1.53 Volts [0xBF] (VIN2)
    Voltage 7 1.89 Volts [0xEC] (VIN4)
    Temperature 0 50°C (121°F) [0x32] (SYSTIN)
    Temperature 1 64°C (146°F) [0x7F] (CPUTIN)
    Temperature 2 39°C (102°F) [0x4E] (AUXTIN)
    Fan 0 2987 RPM [0x71] (SYSFANIN)
    Fan 1 2836 RPM [0x77] (CPUFANIN0)
    Fan 2 1269 RPM [0x85] (AUXFANIN0)
    Hardware registers
    bank 0
    00 01 63 01 FF 00 00 00 00 01 01 01 01 3C 3C 0A 0A
    10 01 00 02 7F 01 BF BF 3C 43 00 FF FF 24 32 00 E3
    20 AB E4 CD CC FF BF FF 32 71 78 85 E7 00 C0 00 00
    30 00 00 00 00 20 00 00 00 00 00 00 88 00 00 00 FF
    40 03 00 08 DE FF 00 03 A4 2D 44 01 C4 18 95 00 A3
    50 FF FF 00 FF FF FF 00 80 88 60 FF FF 19 04 FF 05
    60 AB E4 CD CC FF BF FF 32 71 78 85 E7 00 C0 00 00
    70 00 00 00 00 20 00 00 00 00 00 00 88 00 00 00 FF
    80 01 63 01 FF 00 00 00 00 01 01 01 01 3C 3C 0A 0A
    90 01 00 02 7F 01 BF BF 3C 43 00 FF FF 24 32 00 E5
    A0 AB E4 CD CC FF BF FF 32 71 78 85 E7 00 C0 00 00
    B0 00 00 00 00 20 00 00 00 00 00 00 88 00 00 00 FF
    C0 03 00 00 DE FF 00 03 A4 2D 44 01 C4 18 95 00 A3
    D0 FF FF 00 FF FF FF 00 80 88 60 FF FF 19 04 FF 05
    E0 AB E4 CD CC FF BF FF 32 71 78 85 E7 00 C0 00 00
    F0 00 00 00 00 20 00 00 00 00 00 00 88 00 00 00 FF
    bank 1
    50 3F 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
    bank 2
    50 15 00 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
    bank 3
    bank 4
    50 1B 13 00 00 00 FD 00 00 1B 9E 0D 3B 49 00 FF FF
    bank 5
    50 CE 01 E7 FF 00 00 00 00 00 00 00 00 00 00 00 00
    Processors
    Number of threads 2
    APICs
    Processor 0
    -- Core 0
    -- Thread 0 0
    -- Thread 1 1
    Processor 1 ID = 0
    Name Intel Pentium 4 550
    Codename Prescott
    Specification Intel(R) Pentium(R) 4 CPU 3.40GHz
    CPUID F.3.4
    Extended CPUID F.3
    Core Stepping D0
    Technology 90 nm
    Core Speed 3412.0 MHz
    Multiplier x FSB 17.0 x 200.7 MHz
    Rated Bus speed 802.8 MHz
    Stock frequency 3400 MHz
    FID/VID Control no
    Thread dumps
    CPU Thread 0
    APIC ID 0
    Type 01001003h
    CPUID
    0x00000001 0x00000F34 0x00020800 0x0000441D 0xBFEBFBFF
    0x80000004 0x20342029 0x20555043 0x30342E33 0x007A4847
    MSR 0x0000002C 0x00000000 0x11120311
    MSR 0x000001A0 0x00000000 0x20840089
    CPU Thread 1
    APIC ID 1
    Type 01001003h
    CPUID
    0x00000001 0x00000F34 0x01020800 0x0000441D 0xBFEBFBFF
    Binaries
    Monitoring
    LPCIO
    LPCIO Chip ID 0x88
    Config Mode LDN 0xB
    Hardware Monitors
    Hardware registers
    bank 0
    bank 1
    bank 2
    bank 3
    bank 4
    bank 5
    Processors
    Number of threads 2
    APICs
    Processor 0
    -- Core 0
    -- Thread 0 0
    -- Thread 1 1
    Processor 1 ID = 0
    Codename Prescott
    CPUID F.3.4
    Extended CPUID F.3
    Core Stepping D0
    Technology 90 nm
    FID/VID Control no
    Thread dumps
    CPU Thread 0
    APIC ID 0
    Type 01001003h
    CPUID
    CPU Thread 1
    APIC ID 1
    Type 01001003h
    CPUID
    --------[ EVEREST Ultimate Edition ]------------------------------------------------------------------------------------
    Version EVEREST v5.30.1900
    Benchmark Module 2.4.273.0
    Homepage http://www.lavalys.com/
    Report Type Quick Report
    Computer
    Generator
    Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP RTM)
    Date 2010-05-03
    Time 21:47
    --------[ CPU ]---------------------------------------------------------------------------------------------------------
    CPU Properties:
    CPU Type Intel Pentium 4 550, 3400 MHz (17 x 200)
    CPU Alias Prescott
    CPU Stepping D0
    Instruction Set x86, MMX, SSE, SSE2, SSE3
    Original Clock 3400 MHz
    Min / Max CPU Multiplier 14x / 17x
    Engineering Sample No
    L1 Trace Cache 12K Instructions
    L1 Data Cache 16 KB
    L2 Cache 1 MB (On-Die, ECC, ATC, Full-Speed)
    Multi CPU:
    Motherboard ID INTEL Deluxe
    CPU #1 Intel(R) Pentium(R) 4 CPU 3.40GHz, 3412 MHz
    CPU #2 Intel(R) Pentium(R) 4 CPU 3.40GHz, 3412 MHz
    CPU Physical Info:
    Package Type 775 Contact LGA
    Package Size 3.75 cm x 3.75 cm
    Transistors 125 million
    Process Technology 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
    Die Size 112 mm2
    Core Voltage 1.425 V
    I/O Voltage 1.425 V
    Typical Power 84 - 115 W (depending on clock speed)
    Maximum Power 101 - 151 W (depending on clock speed)
    CPU Manufacturer:
    Company Name Intel Corporation
    Product Information http://www.intel.com/products/processor
    CPU Utilization:
    CPU #1 / HTT Unit #1 0 %
    CPU #1 / HTT Unit #2 0 %
  7. Best answer
    The problem is that the Pentium 4 does not have any core temperature sensor that can be read directly by the processor itself. Newer Intel CPUs do have core digital temperature sensors that can be read by the CPU. Tools like CoreTemp or RealTemp access these core temperature sensors. This explains why CoreTemp does not work on any Pentium 4 CPU.
    Now Pentium 4 CPUs still have a thermal diode embedded with which the temperature of the CPU can be measured. But for the measuring the CPU alone is not enough. A special hardware monitoring chip (usually the super I/O) is required on the mainboard to measure this temperature. To read the CPU temperature the software has to access this super I/O chip and read the measured temperature from there.
    Your Asus P5AD2-Deluxe Pentium 4 3.4Ghz system uses a Winbond W83627EHF super I/O (placed on the mainboard), which is supported by HWMonitor and many other programs (Open Hardware Monitor fails due to a small bug which will be fixed in the next release). But your Dell Pentium 4 3.2Ghz system seems to use a super I/O chip from SMSC, most likely the SMSC LPC47M584-NC (this should be a chip on the mainboard with a very high number of pins and no heatsink). For this chip there are no datasheets available which make it really hard to access the chip. The result is, that hardly any software supports it.
    So your problem comes from the different mainboards (or to be more correct, from the different super I/O chips on the mainboards).
  8. Well, I'd say that covers it. Thank you for the detailed (and disappointing :??: ) explanation. I guess I will have to listen to the fans for temperature clues.
  9. Best answer selected by group6.
    http://i44.tinypic.com/1e9gzs.jpg
    i donwload core temp . but at me shows nothing :S
    how can i know . my max temp . at me cpu temp is 44 Celsius is this bad .
CPUs Temperature Monitor Processors Windows Vista
