Sign-in / Sign-up
Help with some psu advice
  • Power Supplies
  • Components
Last response: in Components
May 3, 2010 11:22:34 AM
I want to build a new system with the following specs:
Gigabyte GA-P55-UD3R
Intel Core i5-750
4GB Corsair DDR3
HFX Radeon HD5770
1TB WD hard-drive
Sony DVDRW
I need a psu, but i'm on a tight budget, aprox. 50 UK pounds. What sorts of brands should I be looking at and what sort of power do I need? Is 550W enough, because I found a nice OCZ fatal1ty 550W at 53 pounds. Will it do for my system?
More about : psu advice
May 3, 2010 11:44:34 AM
OCZ 500W Mod XStream Pro PSU - 2x PCI-E 6x SATA is £56.50
its a bit over but its a very good one also Corsair
450W VX Series PSU - ATX12V v2.2 is another good one
that off ebuyer + u can get free Delivery and if your luck it will come next day :)
May 3, 2010 11:45:29 AM
i would go for the OCZ 500W Mod XStream Pro PSU - 2x PCI-E 6x SATA
May 3, 2010 11:47:56 AM
what site did you get the price for the OCZ fatal1ty 550W ?
May 3, 2010 11:58:58 AM
I won't want to do crossfire in the near future, so this should be enough for me.
May 3, 2010 11:59:45 AM
go for it then that will do, unless u ever want to do crossfire
May 3, 2010 12:00:08 PM
So 550 W are enough for the above-mentioned setup ?
May 3, 2010 12:05:05 PM
yep it will be fine, where are u geting the 5770 from?
May 3, 2010 12:10:16 PM
scan.co.uk
I'm ordering most of the parts from there, except for the memory.
DVD-RW, wireless and bluetooth adaptors, cables and auxiliaries( anti-static stuff, paste) I ordered on amazon.
May 3, 2010 12:11:25 PM
OCZ fatal1ty 550W will be fine :)
May 3, 2010 12:16:08 PM
have a look at ebuyer the 5770 cost less and it come with Delivery free
also what anti-static stuff are u using? if its a case clip what case?do you have a case yet?
if you need some help just ask as i could find you a good spec at a low cost
May 3, 2010 12:23:35 PM
Antec Three Hundred if its been painted inside the Anti-static wrist band will no be not much use,
