Sign-in / Sign-up
Solved
Building new AMD System for friend.. need some help
  • New Build
  • AMD
  • Systems
  • Product
Last response: in Systems
February 25, 2010 3:24:32 PM
So a friend of mine wants a new system built, and I need a little advice.
USAGE: Gaming-Minly jsut one game called FLight Simulator X. Web browsing, office documents.
Price Range- 600 MAX
Parts not needed- Monitor, mouse, keyboard
Time of purchase-ASAP
Additional Comments- He will be running 64 bit WIndows 7
I dont know much about AMD. I did some brief research about the system, but is this even possible for 600 dollars?
More about : building amd system friend
February 25, 2010 3:40:14 PM
Kinda Confused do you need an OS?
m
l
February 25, 2010 3:43:07 PM
Sorry posted the message from a blackberry. No OS will be needed. Haver a copy of Windows 7-64 bit/
m
l
February 25, 2010 3:54:03 PM
Seagate 7200.12 500GB 55
HD5770 153
CL7 1600 Corsair XMS3 $115
Antec 200 and Antec Earth watts 650 105
Hyper 212 Plus and Optical 40
Here are a couple of options.
1) Non-X-fire but with USB 3 support
GIGABYTE GA-770TA-UD3 and AMD Athlon II X3 425 Rana 157
Total with option 1 is 604 after MIR or 624 w/o MIR
2) Supports Xfire and USB3
ASUS M4A785TD-V EVO and AMD Athlon II X3 425 Rana 177
Total with this option is 645 w/o MIR 635 with Mir
***Edit***If you dont plan on overclocking then you can save 20 bucks and not get the Hyper 212+
m
l
Best solution
a c 124 À AMD
February 25, 2010 3:58:15 PM
Case: Antec 300 + 430 Watt PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
CPU: AMD Athlon II x4 620 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Motherboard: ASUS <4N68T - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Memory: OCZ Platinum 4GB (2x2GB) DDR3 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Graphics: Sapphire ATI HD 5670 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Hard Drive: Seagate 7200.12 500GB - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Optical Drive: Lite-On DVD Burner - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Total before taxes (and/or shipping): $520.89
-Wolf sends
February 25, 2010 4:06:28 PM
Awesome. Thanks guys Thik I got an idea on what to do now. Appreciate the replies.
m
l
March 7, 2010 2:36:43 AM
Best answer selected by phesoge.
m
l
