Hi guys,
I just built a new computer with a gigabyte p55-ud4p, installation was fairly smooth, got it to post, installed windows 7 64x, and started installing various programs as well as the mobo drivers.
Everything goes smoothly when the computer is on, sound, internet, etc, I can install and play games just fine. It's when I shut down that problems occur.
The first time I booted up the computer, I installed everything off of the gigabyte mobo cd, wouldn't restart.
Reinstalled windows, this time I only installed my ethernet drivers, restarted, thing were fine for a while, installed a few games etc. Then I installed the latest windows update, computer hung up, went into dos when starting up and said something about checking disk and file corruption, it fixed itself and it was fine. So I thought it might have something to do with the windows update, I decided not to update for a few days and the computer seemed to start up fine.
Then, I installed another game, as well as core temp, and when it restarted, it hung up, system restored back to an earlier point and I was able to start up again. I feel like any "system" related installs are causing problems.
I feel like this has to be a motherboard issue, or a hard drive issue, since all the other components are working just fine if I leave the computer on. Any ideas? Do I need to flash the bios? I'm hesitant to even install anything off the gigabyte cd or website, or is it the hard drive? Check disk came up negative but I don't know how else to tell aside from getting another hard drive to test.
Thanks for the help.
