I am in the final stage of creating my W/C build and have a couple of questions. First, how do I clean out my brand new pump to make sure there is nothing inside of it? Second, what is the best way to perform a leak test? Last, is there any visually appealing way to add a purge to my loop? I have seen white plastic ones that look like cheap pvc and I don't want that.
Thanks in advance!
Thanks in advance!
