Solved
Help with 1600Mhz RAM on 1333Mhz M.B.
Last response: in Memory
Hi, I've got a pair of 2GB G.Skill Ripjaw series 1600Mhz RAM sticks (cas latency is 9). They are currently underclocked to 1333Mhz on my MSI 890FXA-GD70 MB which supports 1333Mhz and 1600Mhz (OC). My questions are ...
1. If I wanted to increase RAM speed to 1600Mhz, would I need to overclock my CPU (Phenom II x4 955 BE) as well?
2. Is it possible to keep my speed at 1333Mhz and tighten the timings? If so, which would give me better performance (1333Mhz w/ tight timings or 1600Mhz w/ cas 9)
3. Would tightening my timings still be overclocking?
As you can tell, I'm completely new to overclocking and am a little scared of it. :(
More about : 1600mhz ram 1333mhz
Best solution
Well, if your ram is 1600 underclocked to 1333 and you wanted to clock up to 1600 you should try stock timings for your 1600 mhz, try 1T instead of 2T and if you have problems put it at 2T. Yes, you'd have to oc the cpu, bus ht and probably have to raise the v-core. very tedious. kinda fun if you have the time.
Great, thanks. One more question, does OC'ing actually bring down the life of a product? Or is it just the extra heat from OC'ing? My CPU is at 23C idle, and I ran Prime95 for about 5 mins and it hit 60C, I think I'll get an aftermarket cooler before I OC.
Related ressources
Ok, thanks for all the feedback, one last question. I've got an MSI board with an easy overclock dial and OC genie. What should I use for an easy overclock maybe up to like 3.4Ghz or something? Will the OC genie OC my RAM as well? And will the genie take care of voltages and all that? (Cause that's what I'm really scared of when thinking of overclocking) I heard that high voltages are way way more dangerous than heat.
Ask the community
