Hard disk can not load on the system
Hello,
my simple question is when i started the system after some time will showing the message on the monitor screen"the CPU overheating". Then i have disconect the hard disk drive
then my pc is working very smoth. plz tell me the what is the eject problem. I think main issue is hard disk.
Plz reply on my id
sandeepgp07@gmail.com
1 answer Last reply
More about hard disk load system
  1. Uhh what? I get from that:
    -You are in windows
    -it displays a message that your CPU is overheating disconnect your hard drive
    -you disconnect your hard drive while you computer is on
    -everything works fine...
    That of course makes no sense. Please rephase stuff and provide us with more details so I don't have to fill in the blanks.
    Also, no one is going to email you.
CPUs Hard Drives Monitors
