Closed
Fan Controller Help
I'm looking for a 5.25" bay fan speed controller that will work with these fans:
http://www.amazon.com/gp/product/B0026ZPFCK/ref=oh_deta...
This is the one I was looking into, but I am unsure if it is compatible, so I will hold out for a reply.
http://www.amazon.com/Sentry-Mesh-Controller-Watts-Chan...
I'm just not entirely certain what all of the electrical specifications mean when it comes to compatibility. So I'm asking for a link to a product that will work for me, and if you are feeling generous, a little education on why it will work / won't work?
I'd prefer to buy from Amazon or Newegg, with a $20-30 price range. That doesn't mean I'm unwilling to spend more, but that is where I'd like to land, if at all possible.
Thanks in advance for help!
More about : fan controller
Best solution
They will be fine.
When it comes to fans and fan controllers, there isnt anything to really worry about with compatibility. Only thing may be the wattage on each channel, but unless your chaining multiple fans off the one channel, it isnt a concern.
