Looking at building one of these two systems in the next month (waiting on Tax Return).
Looking for opinions on builds and which is preferable for mostly gaming and general internet stuff.
Trying to stay right at around $900 US not including shipping.
--General--
Case - Antec 300 http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
Case Fans X2 - http://www.newegg.com/Product/Product.aspx?Item=N82E16835168006
HDD - Western Digital 250GB http://www.newegg.com/Product/Product.aspx?Item=N82E16822136113
DVD - SAMSUNG Black 22X http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175
Video - Radeon HD 5770 http://www.newegg.com/Product/Product.aspx?Item=N82E16814150447
Compound - http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
---Intel---
CPU - i5-750 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
CPU Fan - ARCTIC COOLING Freezer 7 Pro http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
MoBo - BIOSTAR TP55 LGA 1156 Intel P55 http://www.newegg.com/Product/Product.aspx?Item=N82E16813138161
Mem - Kingston HyperX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 http://www.newegg.com/Product/Product.aspx?Item=N82E16820104140
PS - Eagle Tech ET-PSVTX550E-BK http://www.newegg.com/Product/Product.aspx?Item=N82E16817193069
---AMD---
CPU - X4 955 Black Edition Deneb http://www.newegg.com/Product/Product.aspx?Item=N82E16819103808
CPU Fan - Rosewill RCX-ZAIO-92 http://www.newegg.com/Product/Product.aspx?Item=N82E16835200056
MoBo - GIGABYTE GA-MA790XT-UD4P http://www.newegg.com/Product/Product.aspx?Item=N82E16813128378
Mem - Patriot Viper 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 http://www.newegg.com/Product/Product.aspx?Item=N82E16820220286
PS - RAIDMAX HYBRID 2 RX-730SS 730W http://www.newegg.com/Product/Product.aspx?Item=N82E16817152036
Which one would be better for a 2yr upgrade pattern? The Intel MoBo I was not sure about, but spec wise seems the best bang for buck, I always build for SLI but never end up doing it so figured I could lose the second PCI slot.
Current System is an E8400 stock fan O.C. to 3.6; ASUS P5N-D LGA 775; CHAINTECH GSE96GT; 4 GB Mushkin Enhanced Silverline DDR2 800 (PC2 6400); stuffed into an Antec 300 with a SunBeam 750 Watt
--General--
---Intel---
---AMD---
